Yet again Ethernet mod
I followed FAQ and several post here to try connecting an Ethernet based payload and get access to it from ground through herelink radio link
I’ve build this setup
And it works great I’ve well fing both eth0 on ground and air units
optimus:/ $ ifconfig
br-vxlan  Link encap:Ethernet  HWaddr b8:8d:f1:ff:85:03
          inet addr:192.168.144.11  Bcast:192.168.144.255  Mask:255.255.255.0
          inet6 addr: fe80::ba8d:f1ff:feff:8503/64 Scope: Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:33 errors:0 dropped:0 overruns:0 frame:0
          TX packets:94 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:1820 TX bytes:19918
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope: Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:116795 errors:0 dropped:0 overruns:0 frame:0
          TX packets:116795 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:6631247 TX bytes:6631247
eth0      Link encap:Ethernet  HWaddr 00:0e:c6:86:d8:67
          inet6 addr: fe80::20e:c6ff:fe86:d867/64 Scope: Link
          RX packets:94 errors:0 dropped:0 overruns:0 frame:0
          TX packets:92 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:6263 TX bytes:19228
lmi40     Link encap:UNSPEC
          inet addr:192.168.0.11  P-t-P:192.168.0.11  Mask:255.255.255.0
          inet6 addr: fe80::d196:9657:f759:a2a/64 Scope: Link
          UP POINTOPOINT RUNNING NOARP MULTICAST  MTU:1550  Metric:1
          RX packets:16550 errors:0 dropped:0 overruns:0 frame:0
          TX packets:98053 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:500
          RX bytes:864963 TX bytes:5447009
vxlan1    Link encap:Ethernet  HWaddr d2:a3:f9:9d:e7:72
          inet6 addr: fe80::d0a3:f9ff:fe9d:e772/64 Scope: Link
          TX packets:285 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1820 TX bytes:58824
wlan0     Link encap:Ethernet  HWaddr 00:18:07:51:85:03
          inet addr:192.168.9.130  Bcast:192.168.9.255  Mask:255.255.255.0
          inet6 addr: fe80::218:7ff:fe51:8503/64 Scope: Link
          RX packets:3368 errors:0 dropped:0 overruns:0 frame:0
          TX packets:2206 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:580646 TX bytes:181345
optimus:/ $
and for air unit
$ ifconfig
          inet addr:192.168.0.10  P-t-P:192.168.0.10  Mask:255.255.255.0
          inet6 addr: fe80::f5ef:57ed:1189:8605/64 Scope: Link
          RX packets:15737 errors:0 dropped:0 overruns:0 frame:0
          TX packets:2686 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:920705 TX bytes:142663
eth0      Link encap:Ethernet  HWaddr 00:0e:c6:86:d7:7d
          inet6 addr: fe80::20e:c6ff:fe86:d77d/64 Scope: Link
          RX packets:22 errors:0 dropped:0 overruns:0 frame:0
          TX packets:96 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:2578 TX bytes:20826
vxlan1    Link encap:Ethernet  HWaddr a2:6e:b1:c8:2d:74
          inet6 addr: fe80::a06e:b1ff:fec8:2d74/64 Scope: Link
          RX packets:240 errors:0 dropped:0 overruns:0 frame:0
          TX packets:35 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:55384 TX bytes:2116
br-vxlan  Link encap:Ethernet  HWaddr b8:8d:f1:ff:34:69
          inet addr:192.168.144.10  Bcast:192.168.144.255  Mask:255.255.255.0
          inet6 addr: fe80::ba8d:f1ff:feff:3469/64 Scope: Link
          RX packets:261 errors:0 dropped:0 overruns:0 frame:0
          TX packets:12 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:57916 TX bytes:760
          RX packets:7658 errors:0 dropped:0 overruns:0 frame:0
          TX packets:7658 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:480534 TX bytes:480534
br-vxlan:0 Link encap:Ethernet  HWaddr b8:8d:f1:ff:34:69
          inet addr:192.168.42.10  Bcast:192.168.42.255  Mask:255.255.255.0
I can ping 192.168.0.10 or 11 and 192.168.144.10 or 11 from both air and ground units
I’ve fixed payload (192.168.0.20) and pc (192.168.0.50) ip’s
but I can’t ping any thing from or outside herelink units
i’ve also try to fix both IP in 192.168.144.xx range with same result
I’m not a big master in busy box but I was surprised to see no v4 ip on eth0 so I tryied to add an inetv4 addr on eth0
$ su
# ip addr add 192.168.0.15 dev eth0
but It doesn’t change anything
if you have any king of test or ideas to get me a bit further that would be greatly appreciated
I’ve also try to draw an ip addr map :
if you can confirm or correct me that would be very kind be cause a get a bit lost betwenn bridge / devices / loopbacks ip etc
to be a bit more clear I can ping from herelink units ip in red but in or outside herelink units blue ip are not reachable
I would greatly appreciate also more details on difference between interface
bx-vxlan : guessing is the radio bridge
lmi40 : is unit on virtual lan between units
but what is vxlan for ?
thank’s for any tiny bit of info
ps someone said me to include @Michael_Oborne in my message so I’m doing it
thanks again and sorry for disturbing
OK thanks !! sorry for that mistakes I was thinking the opposite
I tried
I modified in this way
PC connected to ground unit gets 192.168.144.20
fictive payload raspberry pi connected to air unit gets 192.168.144.25
when opening a shell on ground unit trough adb I can ping the payload
oga@oga-UX550VD:~$ adb shell
optimus:/ $ ping 192.168.144.10
PING 192.168.144.10 (192.168.144.10) 56(84) bytes of data.
64 bytes from 192.168.144.10: icmp_seq=1 ttl=64 time=31.9 ms
^C
--- 192.168.144.10 ping statistics ---
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 31.984/31.984/31.984/0.000 ms
optimus:/ $ ping 192.168.144.25
PING 192.168.144.25 (192.168.144.25) 56(84) bytes of data.
64 bytes from 192.168.144.25: icmp_seq=1 ttl=64 time=35.9 ms
64 bytes from 192.168.144.25: icmp_seq=2 ttl=64 time=14.6 ms
^C
--- 192.168.144.25 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1001ms
rtt min/avg/max/mdev = 14.630/25.291/35.953/10.662 ms
optimus:/ $
but from PC ground host even with right subnet
oga@oga-UX550VD:~$ ifconfig
docker0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        inet 172.17.0.1  netmask 255.255.0.0  broadcast 172.17.255.255
        ether 02:42:b0:34:bc:df  txqueuelen 0  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
enx34298f908abf: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.144.20  netmask 255.255.255.0  broadcast 192.168.144.255
        inet6 fe80::751a:27f1:a137:490b  prefixlen 64  scopeid 0x20<link>
        ether 34:29:8f:90:8a:bf  txqueuelen 1000  (Ethernet)
        RX packets 19  bytes 5257 (5.2 KB)
        TX packets 140  bytes 11066 (11.0 KB)
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 43303  bytes 3902037 (3.9 MB)
        TX packets 43303  bytes 3902037 (3.9 MB)
wlp3s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.9.138  netmask 255.255.255.0  broadcast 192.168.9.255
        inet6 fe80::3b61:efab:a24:1368  prefixlen 64  scopeid 0x20<link>
        ether 34:41:5d:a8:8e:73  txqueuelen 1000  (Ethernet)
        RX packets 1506170  bytes 966500548 (966.5 MB)
        TX packets 1066359  bytes 578018198 (578.0 MB)
I can’t reach anything
oga@oga-UX550VD:~$ ping 192.168.144.10
From 192.168.144.20 icmp_seq=1 Destination Host Unreachable
From 192.168.144.20 icmp_seq=2 Destination Host Unreachable
From 192.168.144.20 icmp_seq=3 Destination Host Unreachable
^C
4 packets transmitted, 0 received, +3 errors, 100% packet loss, time 3065ms
pipe 3
oga@oga-UX550VD:~$ ping 192.168.144.11
PING 192.168.144.11 (192.168.144.11) 56(84) bytes of data.
^C
--- 192.168.144.11 ping statistics ---
10 packets transmitted, 0 received, 100% packet loss, time 9203ms
oga@oga-UX550VD:~$ ping 192.168.144.25
From 192.168.144.20 icmp_seq=4 Destination Host Unreachable
From 192.168.144.20 icmp_seq=5 Destination Host Unreachable
From 192.168.144.20 icmp_seq=6 Destination Host Unreachable
^C
8 packets transmitted, 0 received, +6 errors, 100% packet loss, time 7149ms
pipe 4
Thank’s a lot for your help
it helped a lot to move forward ( just a small move but forward :wink: )
ps : looks to be more an issue of PC side … but I’m a bit lost :
oga@oga-UX550VD:~$ nmap -sP 192.168.144.0/24
Starting Nmap 7.80 ( https://nmap.org ) at 2021-09-23 15:36 CEST
Nmap scan report for oga-UX550VD (192.168.144.20)
Host is up (0.00024s latency).
Nmap done: 256 IP addresses (1 host up) scanned in 3.34 seconds
we tried on several different pc / Linx / windows and always same result :cry:
:thinking:
C:\Sdk\platform-tools>adb shell
optimus:/ $ clear
br-vxlan Link encap:Ethernet HWaddr b8:8d:f1:ff:ba:01
inet6 addr: fe80::ba8d:f1ff:feff:ba01/64 Scope: Link
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:77 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 TX bytes:17650
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 TX bytes:0
eth0 Link encap:Ethernet HWaddr 00:e0:4c:36:01:cd
inet6 addr: fe80::2e0:4cff:fe36:1cd/64 Scope: Link
RX packets:144 errors:0 dropped:0 overruns:0 frame:0
TX packets:31 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:15291 TX bytes:6484
inet6 addr: fe80::2de7:7916:d010:3dae/64 Scope: Link
TX packets:2490 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 TX bytes:187964
vxlan1 Link encap:Ethernet HWaddr 1a:3d:eb:a2:80:68
inet6 addr: fe80::183d:ebff:fea2:8068/64 Scope: Link
TX packets:236 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 TX bytes:52222
wlan0 Link encap:Ethernet HWaddr 00:18:07:64:ba:01
inet addr:192.168.137.7 Bcast:192.168.137.255 Mask:255.255.255.0
inet6 addr: fe80::218:7ff:fe64:ba01/64 Scope: Link
RX packets:360 errors:0 dropped:0 overruns:0 frame:0
TX packets:244 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:50214 TX bytes:36927
optimus:/ $ /bin/busybox brctl show
bridge name bridge id STP enabled interfaces
br-vxlan 8000.b88df1ffba01 no vxlan1
optimus:/ $
cant connect my pc to herelink
Can you help me?
we cant see bridge(interface) eth0
it looks you have a well detected eth0 on the ground unit a least
I dont know what about the air unit but if you follow this Herelink Ethernet - #3 by Michael_Oborne
you should see also a eth0 on air unit
if you fix you pc and your payload IP in the 192.168.144.xx subnet you should be able to ping your payload from ground unit and you should be able to ping your payload from PC also that’s here I have an issue
when trying to make an arp request from PC on GCS
arp -an 192.168.144.11
? (192.168.144.11) at 00:0e:c6:86:d8:67 [ether] on enx34298f908abf
but 00:0e:c6:86:d8:67 is HW adress of Eth0 of GCS not the bx-vxlan one
when trying to ping from payload (192.168.144.25) to PC side
(192.168.144.20) it dont get’s to the end neither ( not surprising)
but the arp cache is showing
pi@raspberrypi:~ $ arp -an
? (192.168.144.20) at <incomplete> on eth0
? (192.168.1.184) at 34:41:5d:a8:8e:73 [ether] on wlan0
? (192.168.144.11) at b8:8d:f1:ff:85:03 [ether] on eth0
where b8:8d:f1:ff:85:03 is mac addr of br-vxlan on herelink ground unit
it looks that missing some routing table input to get connecttion between br-vxlan and eth0 on ground unit …
any one can helps me a bit I’m getting stuck and my boss start to look at me with black eyes !!
@Michael_Oborne
firstly, arp is not a routable protocol, its part of the broadcast domain.
br-vxlan is a bridge interface, with multiple interfaces under it. so i dont know what your intent is, i think might need to go back to basics.
dear @Michael_Oborne
It is possible to guide my problem Herelink Ethernet - #53 by Michael_Oborne
I’m ok with you just doing ARP requests to know on what interface I’m falling
speaking of basics I’m still stuck when trying to ping 192.168.144.xx from PC side …
despite everything looks ok and ping is ok between remote and payload
My goal is just to be able to do a simple ping bitweeen pc host hooked to remote and pâyload connected to air unit
PC(192.168.144.20) >> remote (192.168.144.11) >> … >> air unit (192.168.144.10) >> payload (192.168.144.25)
and back
It works if I connect PC over Wifi Acces point of remote
that in my opinion mean that it’s missing a link between br-vxlan bridge and eth0 this link is set for wlan0 interface but not for eth0 one
I have the same problem
but i cant connect to Rasperypi ( airunit )
the new ethernet interface is not automatically added to the bridge( GCS)
are you using an external power supply for you air unit lan interface adapter ?
do you have follow recommmendation for compatible adapters ? as explained here Herelink Ethernet compatible hardware
is your air unit ( and remote ) up to date ?
How To Update Firmware - CubePilot
if yes to all theses questions I can’t help you more it should work try anoter units
Yes, everything is correct
still on wifi (using AP)
pc 192.168.144.30
payload 192.168.144.25
ping is ok in both direction
