mohd94
(Mohammad)
1
Here is the problem again:
I’m using Mission Planner and I have already set the parameters described here
https://docs.cubepilot.org/user-guides/here-3/here-3-manual#1.-using-ardupilot-firmware
but yet I still can’t see my compass.
If there is a hardware problem, how can I be sure it’s a compass problem or a cube problem?
Alvin
2
Does the GPS working well?
You may also try to connect it via SLCAN and change the node id to a different one.
mohd94
(Mohammad)
3
I still receive No GPS on the MP Data window. Can you point me out where can I find the documents to change the node id?
Alvin
4
It’s right under the link I shared earlier
mohd94
(Mohammad)
5
Thanks for the help!
Unfortunately, MP can’t see my compass in the SLCAN Mode. I think it’s possible the problem is a hardware problem.
Is there anything else I can do?
Alvin
6
Are you able to update it?
mohd94
(Mohammad)
7
I get no update available for the ardupilot.
Alvin
8
Please contact your reseller for RMA.
