I have purchased latest here 4 rtk GPS & base station module. I am using PX4 & Qground control. As per the instructions, I am connecting the here 4 rtk base, the survey in is not getting activated and it showing zero satellites and rtk streaming.
Here + base station was plug in solution. Is it because QGC, is not supporting Here 4 rtk base station?
Hi Vishal, can you try updating the Ublox module on Here4 RTK Base with latest firmware downloaded from here NEO-F9P module Firmware Update section. You will need to use Latest u-center application to do so.
Also please note that L5 signal is by default disabled on Neo F9P modules, so you may need to enable that from View → Generation 9 Configuration view . Also follow the instructions here to override signal health https://content.u-blox.com/sites/default/files/documents/GPS-L5-configuration_AppNote_UBX-21038688.pdf . We will work on getting this automated in QGC.
Above is already automated on Here4 Rover, just ensure that you are running atleast v1.13 firmware Releases · CubePilot/GNSSPeriph-release · GitHub and have parameter GPS_DRV_OPTIONS set to 32 for enabling and overriding L5. No other changes should be needed on Here4 Rover.
I am seeing the fence led is Blinking strongly ON in here 4 rtk base, but not in here + base. Does this have something to do with QGC? Does QGC have support of ublox NEO-F9P or it have only ZED-F9P support?
@JulianOes I am using PX4 v1.13.2, here 4 rover has no issues. I want to use the here 4 RTK solution, which have higher convergence.
