Can you please try again?
Most probably .webm videos are issue for Safari.
Now it works
Go pro hero 9 is it possible with herelink?
I would like to buy a last Go pro 9 with the media module but I donât know if this version is good for the herelink
Any camera with hdmi output will be possible to use with herelink except for the analog camera.
Thanks for your answer
this is heavy to place on a drone ! ?
Which camera do you have in mind and what are the settings .
I am trying with the THIEYE D60+ but have no luck âŚ
What problems are you facing with it ? @sibujacob
I would suggest to go with the gopro.
This the screenshot from the madrc youtube video. In this list, there are list of compatible gopro which you can use it
Is this working flawlessly without any glitch âŚWhy do you want the fan !!
Hello, This is good testing practice as this unit is designed for airflow cooling.
The error that i receive is 404 error on the Herelink display while using Solex. We have connected the FC orange cube also.
In qgc it works ?
No. it does not work either in QGC or Solex. What i found recently is that the LED 1 indicator has to provide a GREEN or RED indication if an HDMI signal is detected from the CAM ( THIEYE D60+) from either of the HDMI ports . Well we didnât see this indicator light .
Now I suspect that the original Micro HDMI cable may be faulty , one which is supplied with Herelink. I have requested my colleague to check PINS 4,7,10,13,16 for GND continuity . I strongly suspect the cable manufacturer delibrately avoided some ground wires for selling a cheap cable making a better profit and probably thinking that the air unit or CAM would have GND points joint somewhere on the circuit board :))
GOPRO may be lucky to have these pins grounded internally on their circuit board which is why they work out of the box !! There is no further magic behind why only some HDMI cams work âŚ.LOL
Maybe you can try to use any other HDMI cable that suits your needs for your specific camera with proper connections for ground pin, etc.
This is the other funny scene .:)) For such a big Herelink Air unit ,they provided a small HDMI port !!
Micro HDMI cables are not available in India commonly and also i donât see them in China as well .
Hi Patrik,have you got a link to that av convertor please so I can order one and have a go at this great idea you have done,many thanks
Hello Marty
Actually it is the chepest you can get from china, we order them from alibaba but you can certainly get them from amazon
Hi Patrick,thank you for your reply,is this the convertor please,if so will order now and also will be using an fpv camerahttps://www.amazon.co.uk/Converter-Amtake-Composite-Adapter-Compatible/dp/B07MJTR9KS/ref=sr_1_2_sspa?adgrpid=105051582473&dchild=1&gclid=Cj0KCQjwnueFBhChARIsAPu3YkSwf3mE8WMrDcYzjfDOWG9bgORJ4tRTlSMvU320IkAdKxZ7S1c6pNIaAm_bEALw_wcB&hvadid=446043236324&hvdev=c&hvlocphy=9046835&hvnetw=g&hvqmt=b&hvrand=11414168304256286320&hvtargid=kwd-5729176650&hydadcr=5059_1827828&keywords=av+to+hdmi+adapter&qid=1622801855&sr=8-2-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUExRjlLVDBGSjYxRkRDJmVuY3J5cHRlZElkPUEwNTMxNjg3MzNHV1JDSTZSVktaWSZlbmNyeXB0ZWRBZElkPUEwMTUzMTI2NUtRS1FWUFBJUzJGJndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
Yep, thats the one
thank you kind Sir will order now and just as a warning expect more questionâs, I appreciate all you do for the community
