Hi @philip,
I just update my herelink directly from the remote unit. Apparently there was a new version waiting for me to update it. I woulsd like to know which changes had been done. How can we see if a bug has been removed?
Hi @philip well I do not know how to know which version I am in. I just yesterday run the system updates and a new update was available. I installed it. How can I know the version? How can I know what was changed, improved in the new version. @Michael_Oborne The “bug” I am talking about is this:
It is not directly related to herelink, but it is critical for the ones we are using QGroundControl
Hello everyone.
today I received a here link. it was working well and connected with cube orange. After some time of charging. I noticed a strange problem in the ground module. the display brightness is too low, can’t able to see what is in the display. Initially, I thought the module is switched off, later noticed the display is on, but the display brightness is too low. have anyone noticed this issue. How I can troubleshoot this problem.
might be due to adaptive screen brightness is turned on. just go settings and disable “adaptive screen brightness”. and you’ll be able to adjust the brightness of the display.
Hi all, I am getting an error message that qgroundcontrol should be running 3.3 or higher… This is after updating ground and airside. Any thoughts on this?
@philip i have updated herelink yesterday, unfortunately it needs registration key but i dont have any. i want to upload the old firmware. kindly help in this regard.
Thanks!!!
