Is anyone having problems pairing the air unit after updating to the latest version: BRU01210730
I did this update because qgroundcontrol said that the current version wasn’t the 3.3 version, so I update and then I realized that the pairing with the air unit was gone, and after trying to re-pair I didn’t succeded.
There is a new UI by the way so I don’t know if the steps to setup changed or something…
Just checked it… thank you very much mate, at the moment I am pushing the new firmware to the air unit, again, just in case, and then i will perform the hw js calibration as depicted in the video, as expected I was doing it wrong because I couldn’t see the little details…
Thanks again any update I will leave it here.
As a sidenote, i couldn’t update the air unit just using the flasher, but I needed to do some little “hacking” with the google usb drivers and that should be added to the instructions
I’m having issues trying to get my “Google USB Driver” installed on my HP pavilion x360 laptop
Can you please explain this ‘lil bit of hacking’ you say you had to do?
