Thanks for the beta update - fixed most of the issues I had.
Now I have two new issues about the QGC button settings:
Text in [Settings → Buttons → General] cutoff in QGCs default UI scaling (100%), only readable if scaled down in QGC settings. And even if readable, I really can’t imagine what these settings are supposed to do…
Default scaling (100%):
Button actions do not work at all: No matter what I do setup in [Settings → Buttons → Button Assignment] (e.g. flightmode change), nothing seems to happen when I press the button. The according number flashes when the button is pressed but nothing happens. Maybe the “enable” checkboxes from the previous firmware version are missing? What do the grey “repeat” boxes mean?
I was also wondering if the Air unit needs to be updated too??? From what I gather it’s basically a QGroundControl update but like many other times I could be mistaken. Thanks
Another thing which seems to be missing is the German translation file. While I can switch to Korean I do not see language changes if I switch to German.
I’m willing to contribute to the translation if someone provides the file.
I think the translation could be limited to the gui parts accessed by the general user.
There is another problem. If using copter 4.0.4 there is a constantly visible popup “Parameters are missing from firmware. You may be running a version of firmware QGC does not work correctly with or your firmware has a bug in it. Missing params:
1.COMPASS_PRIMARY”
From what I understand it is caused by an old version of QGC that does not understand new arducopter compass priority. It should be possible to fix by installing the newest version of QGC. Will you release a newer version of QGC? This bug is seriously annoying…
I think it would be nice if you @sidbh, @philip could provide people who are willing to do beta testing with some information on the progress of resolving the problems. Zero reaction on our/issues feels kind of odd. I know you are very busy, but please provide an update and a time horizon now and then.
