Many thanks. Beta Installation went smoothly yesterday. If I need to go back to stable I will ask for help then in case required.
@Michael_Oborne
Could you please help on this.
Can you try flashing back as follows
Turn off herelink.
Press Power and D at the same time till you see Fastboot on the screen
Flash the remote via the download flasher file for your OS
This will put you back to stable
In the new Herelink Settings App: I cannot find a way anymore to allocate the Wheel to SBUS 2 instead of SBUS 1. Has that functionality gone missing or I just donāt find it?
Regards,
Sven
here is the link that I followed as you @MadRC instructed. still, the issue occurs.
https://drive.google.com/drive/folders/1W9Jnt0-laZ9ViGnAl66DTQ0FpC63JeYX?usp=sharing
Ok, got it. Channels numbers are different than before beta update. SBUS 1 is Channel 1 to 16 and SBUS 2 is now Channel 17 to 32.
Just as a matter of interest have you tried updating on another PC ?
Also do you have an SD card in stalled. If so please remove.
This is really strange and may be a failure. If nothing else works I would speak with your dealer.
Yes, I tried with another PC. Still the issue persists.
I donāt have an SD card installed.
Did I need to contact my dealer?
Hello!
Just tried new beta firmware and it has nice features, but with beta, I have troubles with HDMI compatibility. After update my herelink is not recognizing HDMI signal from chinese Topotek gimbal, but with other devices works fine. On the current stable firmware version of the airunit and the remoteunit I have a clear and nice video, please add support of my gimbal into the next beta, thanks!
Thanks @Michael_Oborne
Just in case:
To get back to factory image do I just run the flasher file on ground and air unit? Or is some other sort of reset procedure required?
Regards, Sven
Yeah just run the flasher, for Both sides
regards
I can Upgrade ground unit but i canāt upgrade air unit. Could tell the steps of flasher_win to flasher_win bata? since I run the file (flasher_win) it proceeds to install but not Beta Iām kinda new to this.
hi!
The beta release supports 720? I have updated my system and I can not longer see the camera. It can be āpatcheableā with the 720 patch?
the GCS unit you need to update to beta via OTA.
the flasher app is only for the air unit
I updated my controller to the new firmware the other day using the OTA method but now my joy sticks donāt work.
I tried HW and recalibration but when I move the sticks nothing registers on the software.
the Wheel works and registers that it moves. any thoughts? kinda dead right now because I donāt want to upgrade the Airunit until I know the ground control works.
I see the notes that I cant roll back a version and this concerns me.
2nd note question⦠the ā2D2ā setting under controller settings, when I select it to open the app it crashes and gives reports of it stopped working. I have never tried to open it prior to the patch but now it donāt work, and what is it? does it have something to do with joy sticks not working?
any help would be greatly apricated.
Hi, anyone? 720P its supported by the beta release?
thanks
yes 720 should be working
ā¦didnĀ“t work for me⦠![]()
Im using a NextVision cameraā¦
Can you give me a hand with this? Thanks
Ive just release an updated beta to address some issues in the last beta
- fix a possible reboot if wifi comms fail
- fix a slow down issue (air unit needs the update) goto herelink settings > airunit, and use the 3 buttons across the top
- updated QGC and solex to fix the button issue
QGC might need to be āresetā in the app settings āclear dataā etc
