How to create bridge (question)
we need create bridge for connect remote unit to PC
Is this method correct?
1|optimus:/ $ /bin/busybox brctl addif br-vxlan eth0
brctl: bridge br-vxlan: Operation not permitted
You can use the UDP method
https://docs.cubepilot.org/user-guides/herelink/herelink-user-guides/connect-to-mission-planner
dear alvin
we need connect ethernet cable and receive air unit data .
USB TO LAN -> AIR UNIT
USB TO LAN -> GCS UNIT
we not see eth0 in optimus:/ $ /bin/busybox brctl show
What adaptor are you using?
Are you following the FAQ?
Also, this discussion may help:
Adapter is acceptable
Because when the command ifconfig
i see eth0
by running command
we didn’t see any ETH0 in interface bridge
just vx-lan
I mean the USB-ethernet adaptor, physically. The device which you use to connect controller to network (eg: ax88179)
yes this is
Did those adb commands and operations in earlier steps succeed on your units?
yes on the airunit
i running this command
ifconfig
eth0
and under interfaces i see eth0
br-vxlan 8000.00e04c360345 no vxlan1
eth0
but in the gcs unit i see this result
if config
eth0
br-vxlan
lo
wlan
we need root device
optimus:/ $ start dhcpcd
start: must be root
Just to confirm, are you at latest stable?
yes
I have been trying for more than a month :pensive:
@philip
@Alvin
@Michael_Oborne
dear @HighFreq71
How can I get back to the beta?
thanks you
This means that this feature is no longer available ?
@Alvin
@philip
@Michael_Oborne
I have exactly the same problem
No, I tried this method
No response received
If you get an answer, please let me know
I try too
There’s a known problem at the moment on the gcs side, which also answers HighFreq71.
