Indoor Autonomous Flight with Cube, ROS and Aruco Board (Ongoing)
Edit 24 Aug 2021: I’m no longer working on this, because I realized this requires constant Aruco in sight otherwise the copter will lose its position data. I think this is not feasible to use as we need aruco placed on ground everywhere it flies. Also the flying altitude is limited as it may lose the sight from bad focusing.
Hi, does anyone remember the indoor autonomous flight tutorial in ardupilot.org ?
It was done by Raspberry Pi 3 with Pixhawk1. I am rewriting the tutorial with newer hardware, which are Pi 3B and the Cube. I hope my tutorial is easy to follow for everybody such that anyone can set it up easily. No more tutorials inside another tutorial and confusing hyperlinks!
Remark:
In this setup, a dummy GPS is set and the aruco marker board is used for positioning. This means that the GPS failsafe is actually never disabled. If the camera lost its sight on aruco board for too long, the positioning system will be turned off. You will need to restart the cube to recover the system. Therefore, I suggest using small/tiny drone for testing. I am working on possible solutions such as adding more aruco marker on ground.
Contents:
1. Hardware Setup and ROS Installation / Using the ROS in Pi
2. SSH Setup in Companion Computer and Remote Computer
3. Time Synchronization / Pi Camera and Cube Parameter Setup
4. Install Necessary Packages in ROS
5. Prepare Your Aruco Board / Camera Calibration
6. Visualization with RVIZ / Robot model
7. Program the Autonomous Path
Install ROS on Raspberry Pi
This tutorial is referenced to the ardupilot.org
Setup is as shown below:
Components
FMU The Cube Black
Companion Computer Raspberry Pi 3B
System Ubuntu Mate 16.04
Camera Pi Camera v2
SD card At least 8 GB
Power Source for Companion Computer 5000mAh Portable USB Power Bank
You will need a keyboard, a mouse, and a HDMI monitor to setup your pi.
Prepare the Operation System on Pi
You can find the detailed installation procedure here but it is troublesome.
You may direct download the workable image at https://www.raspberrypi.org/forums/viewtopic.php?p=1295937#p1295937
Use SD Card Formatter to clear everything on your card and burn the image by balenaEtcher.
Plug the SD card into your Pi and turn it on. Follow the instructions to finish all initial settings.
Install ROS
Detail instruction can be found on ROS.org
Setup your computer to accept software from packages.ros.org.
sudo sh -c 'echo "deb http://packages.ros.org/ros/ubuntu $(lsb_release -sc) main" > /etc/apt/sources.list.d/ros-latest.list'
Set up your keys
sudo apt-key adv --keyserver hkp://ha.pool.sks-keyservers.net:80 --recv-key 421C365BD9FF1F717815A3895523BAEEB01FA116
Make sure your Debian package index is up-to-date
sudo apt-get update
sudo apt-get upgrade
Install ROS Desktop-Full
sudo apt-get install ros-kinetic-desktop-full
Initialize rosdep
sudo rosdep init
rosdep update
Environment setup
echo "source /opt/ros/kinetic/setup.bash" >> ~/.bashrc
source ~/.bashrc
Install dependencies for building packages
sudo apt install python-rosinstall python-rosinstall-generator python-wstool build-essential
Install MAVROS
Detailed instructions can be found here
Or you may type these commands in the terminal to install
sudo apt-get install ros-kinetic-mavros ros-kinetic-mavros-extras
wget https://raw.githubusercontent.com/mavlink/mavros/master/mavros/scripts/install_geographiclib_datasets.sh
chmod a+x install_geographiclib_datasets.sh
./install_geographiclib_datasets.sh
Install RQT tools
sudo apt-get install ros-kinetic-rqt ros-kinetic-rqt-common-plugins ros-kinetic-rqt-robot-plugins
Install catkin tools
sudo apt-get install python-catkin-tools
Setup the Cube
Connect the Cube to ground station (eg: Mission Planner). Go to Config/Tunning > Full Parameter List and modify the following parameters:
SERIAL2_PROTOCOL = 1	to enable MAVLink on the serial port.
SERIAL2_BAUD = 57		baud rate can be up to 921000.
LOG_BACKEND_TYPE = 3	dataflash log files enable.
Connect your Raspberry Pi to the Cube
There are 2 ways to connect them.
Connect via USB
Simply plug connect the Raspberry Pi and the Cube with a USB-to-microUSB cable. The Raspberry Pi should be able to recognize the device.
Connected USB devices can be checked by running the command in terminal as shown below:
for sysdevpath in $(find /sys/bus/usb/devices/usb*/ -name dev); do
        syspath="${sysdevpath%/dev}"
        devname="$(udevadm info -q name -p $syspath)"
        [[ "$devname" == "bus/"* ]] && continue
        eval "$(udevadm info -q property --export -p $syspath)"
        [[ -z "$ID_SERIAL" ]] && continue
        echo "/dev/$devname - $ID_SERIAL"
done
Remember the tty port of the fmu. It will be used later.
Connect via GPIO
Modify one of the telem cable from the Cube
IT IS NOT RECOMMMANDED to connect the 5V pin of the Cube with Pi as Cube is not a proper power source. But if you still want to, connect them as shown in the image.
For Raspberry Pi 3B and newer models, the Bluetooth module occupied UART serial port. To disable the Bluetooth, type the following command in the terminal:
sudo nano /boot/config.txt
Then, add the following lines at the end of config.txt:
dtoverlay=pi-disable-bt
enable_uart=1
Type
sudo nano /boot/cmdline.txt
Modify the file to the following:
dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
Type
sudo raspi-config
Select Advanced Options > Interfacing Options. Disable serial login shell and keep serial interface enabled.
The Cube will not be recognized as an USB device. The port can be check by typing the following commands in terminal:
ls /dev/tty*
/dev/ttyS0 or /dev/ttyAMA0 should be used to communicate with the Cube. For my case, it is /dev/ttyS0
Run ROS on Raspberry Pi
Baud Rate Selection
Raspberry Pi can communicate with the cube for up to 921600 baud rate. However, sometimes ROS could not receive the heartbeat after launched. This may be because of the inaccurate clock on Raspberry Pi. Select a slower baud rate will solve the problem. Selecting 57600 baud rate is most stable and this rate should be enough for general purposes.
Launch ROS
Open a terminal. Type:
roslaunch mavros apm.launch fcu_url:=/dev/ttyS0:57600
you may change the launch setting according to you own setting
roslaunch mavros apm.launch fcu_url:=<tty port>:<baud rate>
If you connect the cube and pi by UART, there may be a chance that the terminal shows No Heartbeat Packet Received. This may because the Bluetooth service has not been disabled. You can completely disable the Bluetooth function by typing sudo systemctl disable hciuart in the terminal.
If permission is denied is shown after roslaunch, type
sudo chmod 666 /dev/<tty port>
You may change it according to your connected tty port:
Set Stream Rate to Enable Data Stream
Open a new terminal. Type:
rosservice call /mavros/set_stream_rate 0 10 1
You can set it in this format according to your application:
rosservice call /mavros/set_stream_rate 0 <frequency in Hz> 1
ROS Topics
Type the following to the terminal to see current available topics:
rostopic list
To see the data in a topic, type:
rostopic echo <topic>
Set Default Connection Port
Open a terminal and type:
roscd mavros
cd launch
sudo nano apm.launch
Find the line <arg name="fcu_url" default="/dev/ttyS0:57600" /> and modify it according to your need in appropriate format:
default="<tty port>:<baud rate>"
After setting, the launch command can be simplified to
Just curious why mavlink1 original setup was using mavlink2
Do you mean SERIAL1_PROTOCOL and SERIAL2_PROTOCOL?
The original setup is mavlink1
SSH is necessary ,otherwise the ROS and program on Raspberry are unobservable during the flight.
First, connect both computers to the same LAN (eg: same WIFI network).
Setup
In Your Raspberry Pi
Check the IP address of the device by open a terminal and type:
ifconfig
Install OpenSSH Server
sudo apt-get install openssh-server openssh-client
Enable SSH service on Raspberry Pi
raspi-config
then select allow ssh
In Your Remote Computer
Check the ip address of the device by open a terminal and type:
ifconfig
Check the Connection
Open a terminal, type:
ping <ip address of remote computer>
ping <ip address of Raspberry Pi>
Define Name for Devices
sudo nano /etc/hosts
Then, type the ip address address and hostname into the file with format <ip address> <hostname>
192.168.xx.xxx pi-name
Such that the IP address can be simplified to a name when using SSH service
Connect the Raspberry Pi
ssh <user name>@<device name>
OR
ssh <user name>@<ip address of Pi>
If login is successful, resources on Rasbperry Pi will be accessible from the remote computer.
Type exit to the terminal to exit the SSH server.
Notice that you need to login again for every new terminal.
Clock/Time synchronization
Confirm Setting is Correct on Raspberry Pi
roscd mavros
cd launch
nano apm_config.yaml
Config the connection and time settings are same as following:
conn:
  timesync_rate: 10.0
  system_time_rate: 1.0
time:
  timesync_mode: MAVLINK
Such that the Raspberry Pi will synchronize once for every seconds
Ensure sys_time plugin is installed on mavros
roscd mavros
nano mavros_plugins.xml
Connect the Cube to ground station (eg: Mission Planner). Go to Config/Tunning > Full Parameter List and modify the following parameter:
BRD_RTC_TYPES = 2	(Mavlink system time)
If there is no BRD_RTC_TYPES in Mission Planner, update your Mission Planner to a newer version.
Set Time Interval with Mavproxy
Time interval can also be set by Mavproxy if it is installed on the Raspberry Pi.
Connect to Mavproxy and type:
module load system_time
Check current time of the device by typing:
time
Set update interval by typing:
system_time set interval <sec>
Enable the Pi Camera
Detailed procedure can be found here
Connect your Camera to the camera port at the centre of Raspberry Pi
sudo apt-get update
sudo apt-get install raspi-config rpi-update
Type
sudo raspi-config
then select Enable Camera
Ensure the setting is same as below:
start_x=1
gpu_mem=128
Run
rpi-update
Test the Camera
raspivid -p 0,0,640,480 -t 0
A 640x480 window should pop up at the top-left corner and shows the real time image from camera.
Mount the Camera
You are supposed to mount your camera in default orientation:
If you need to mount the camera in different orientation, you may modify the parameters in a GUI. This will be mentioned in the part Run all Components.
Since the system calculates position of the camera, not the aircraft itself. It is recommended to mount the camera at the bottom, and face to the ground.
Setup the Cube
AHRS_EKF_TYPE = 2
BRD_RTC_TYPES = 2
EK2_ENABLE = 1
EK3_ENABLE = 0
EK2_GPS_TYPE = 3
EK2_POSNE_M_NSE = 0.1
EK2_VELD_M_NSE = 0.1
EK2_VELNE_M_NSE = 0.1
GPS_TYPE = 0
COMPASS_USE = 0
COMPASS_USE2 = 0
COMPASS_USE3 = 0
SERIAL2_BAUD = 57		(the serial port used to connect to Raspberry Pi)
SYSID_MYGCS = 1			(to accept control from mavros)
VISO_TYPE = 0
Install raspicam_node
Installation
Add source to apt lists
sudo sh -c 'echo "deb https://packages.ubiquityrobotics.com/ubuntu/ubiquity xenial main" > /etc/apt/sources.list.d/ubiquity-latest.list'
Add signing key to trusted list
sudo apt-key adv --keyserver hkp://ha.pool.sks-keyservers.net:80 --recv-key C3032ED8
Run
sudo apt-get update
Build catkin_ws
Jump to next session if you have already installed catkin_ws
Install pre-built package
sudo apt-get install ros-kinetic-catkin
Source your environment
Create a catkin workspace
mkdir -p ~/catkin_ws/src
cd ~/catkin_ws/
catkin_make
Source your workspace
nano ~/.bashrc
Add source ~/catkin_ws/devel/setup.bash at the bottom of file.
OR
Run source devel/setup.bash in terminal everytime before running any package in catkin_ws.
Build from Source
Go to your catkin_ws
cd ~/catkin_ws/src
Download the source for raspicam_node
git clone https://github.com/UbiquityRobotics/raspicam_node.git
Create recognizable file for ROS dependencies
sudo touch /etc/ros/rosdep/sources.list.d/30-ubiquity.list
sudo nano /etc/ros/rosdep/sources.list.d/30-ubiquity.list
Add the following line to the file
yaml https://raw.githubusercontent.com/UbiquityRobotics/rosdep/master/raspberry-pi.yaml
Run rosdep update
Install the ros dependencies
cd ~/catkin_ws
rosdep install --from-paths src --ignore-src --rosdistro=kinetic -y
Compile the code
catkin_make
Run the Node to Confirm Success Installation
Most of the camera in the current market shoud be Pi Camera v2
For a V2.x camera, run roslaunch raspicam_node camerav2_1280x960.launch
For a V1.x camera, run roslaunch raspicam_node camerav1_1280x720.launch
Install OpenCV
Detailed procedure can be found here. You may check the time estimation for each procedure in the link.
This part is tested workable on 3B and 3B+ only.
Warning: Compiling OpenCV is a CPU-intensive task. Make sure your Raspberry Pi has radiators and a fan (or place a powerful external fan next to it) in order to avoid overheating. The Raspberry Pi would not die from overheating, but overheating will throttle its CPU performance, potentially increasing build time.
Raspberry Pi will stop responding for several times. Reboot the Pi to continue its work.
Make sure you have enough time to stick with the Raspberry Pi.
Confirm OS is up-to-date
sudo apt-get update
Install useful utilities
sudo apt-get install screen
sudo apt-get install htop
sudo apt-get install build-essential cmake pkg-config
sudo apt-get install libjpeg-dev libtiff5-dev libjasper-dev libpng12-dev
sudo apt-get install libavcodec-dev libavformat-dev libswscale-dev libv4l-dev
sudo apt-get install libxvidcore-dev libx264-dev
sudo apt-get install libgtk2.0-dev libgtk-3-dev
sudo apt-get install libatlas-base-dev gfortran
Install Python 3
sudo apt-get install python3-dev
Install pip3
sudo apt-get install python3-pip
Get OpenCV 3.2.0 source code
wget -O opencv.zip https://github.com/opencv/opencv/archive/3.2.0.zip
wget -O opencv_contrib.zip https://github.com/opencv/opencv_contrib/archive/3.2.0.zip
unzip opencv.zip
unzip opencv_contrib.zip
Install Numpy, Scipy
sudo pip3 install numpy scipy
Compile OpenCV
cd ~/opencv-3.2.0/
mkdir build
cd build
cmake -D CMAKE_BUILD_TYPE=RELEASE \
    -D CMAKE_INSTALL_PREFIX=/usr/local \
    -D INSTALL_PYTHON_EXAMPLES=ON \
    -D OPENCV_EXTRA_MODULES_PATH=~/opencv_contrib-3.2.0/modules \
    -D BUILD_EXAMPLES=ON ..
Build OpenCV
The Raspberry Pi will overheat if there is no proper cooling. Reboot the Pi and run the command again if it overheated. The progress will be keep after reboot.
Use all 4 cores to build
make -j4
Once OpenCV builds successfully, continue the installation:
sudo make install
sudo ldconfig
sudo apt-get update
Reboot the Raspberry Pi after installation
sudo reboot
python3
Then run import cv2 and cv2.__version__. The version of OpenCV will be shown.
Install aruco_gridboard
If OpenCV extra module failed to build, rebuild them with the following codes:
cd <opencv_build_directory>
cmake -DOPENCV_EXTRA_MODULES_PATH=<opencv_contrib>/modules <opencv_source_directory>
make -j4
Rebuild vision_opencv from source
Clone vision_opencv in your catkin_ws/scr and rebuild everything
cd ~/catkin_ws/src
git clone https://github.com/ros-perception/vision_opencv.git
cd ..
catkin_make -DOpenCV_DIR=/path-to-build-opencv-3.2
If building failed, try
catkin_make -DOpenCV_DIR=/path-to-build-opencv-3.2 -DENABLE_PRECOMPILED_HEADERS=OFF
Install dependancies if any of them is missing during the build
sudo apt-get install ros-kinetic-cv-bridge
sudo apt-get install ros-kinetic-vision-opencv
Check cv_bridge version
cd ~/catkin_ws/devel/lib
ldd libcv_bridge.so | grep opencv
The following result should be shown:
libopencv_core.so.3.2 => /home/jokla/Software/opencv-3.2.0/build/lib/libopencv_core.so.3.2 (0x00007f7acb240000)
libopencv_imgcodecs.so.3.2 => /home/jokla/Software/opencv-3.2.0/build/lib/libopencv_imgcodecs.so.3.2 (0x00007f7acaffe000)
libopencv_imgproc.so.3.2 => /home/jokla/Software/opencv-3.2.0/build/lib/libopencv_imgproc.so.3.2 (0x00007f7ac97ca000)
Clone aruco_gridboard
I modify a lot of things start from here. If you want to know what have I done, following my instructions. If you just want it to work on your system, clone my fork for simplicity.
Simple build:
cd ~/catkin_ws/src
git clone https://github.com/AlphenLai/aruco_gridboard.git
cd ..
catkin_make
Then skip to the next session.
Detailed build:
Clone it into your catkin_ws and build with catkin_make
cd ~/catkin_ws/src
git clone https://github.com/jokla/aruco_gridboard.git
cd ..
catkin_make
The catkin_make should failed at this point.
Go to ~/catkin_ws/src/aruco_gridboard/data/detector_params.yml and ~/catkin_ws/src/aruco_gridboard/src/node.cpp
Open them with text editor and replace cornerRefinementMethod with doCornerRefinement
Add the new OpenCV to the path
cd ~/catkin_ws
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/home/jokla/Software/opencv-3.2.0/build/lib/
Launch the detection node
roslaunch aruco_gridboard detection.launch
Prepare the Aruco Board
Remark
The example grid board assume you are flying a tiny drone. Otherwise, please create your own board by yourself.
Check the IDs You Need
Open the file
~/catkin_ws/src/aruco_gridboard/data/layout-my.yaml
and you will see the following configuration:
ids:
 - 104
 - 111
 - 106
 - 105
 - 101
 - 110
 - 103
 - 102
 - 107
 - 109
 - 100
 - 108
These 12 IDs represent the aruco tags that will be recognized by the system. Edit them if you want to work on a customized board.
Download the Board
The aruco board can be downloaded from here if you do not want to modify it.
Make Your Own Board
Go to
Compile the create_board.cpp by
g++ -ggdb create_board.cpp -o createboard `pkg-config --cflags --libs opencv`
Then, run createboard to generate the image file and content of yaml file.
./createboard
A message will list all neccessary input parameters.
Parameters
w number of markers in x direction
h number of markers in y direction
l length of marker (in pixel)
s space between markers (in pixel)
d type of marker
f ID of first marker (not available if you are not using my fork)
Example input:
./create_board_wID board.jpg -w=10 -h=6 -l=700 -s=140 -d=16 -f=100
An image board.jpg will be created. Copy the ouput from the terminal and create a yaml file. A yaml file layout_<markers in x direction>x<markers in y direction>_<markerLength>.yaml will be automatically create if my fork was used.
Put the new yaml file to ~/catkin_ws/src/aruco_gridboard/data
Open detection_rpicam.launch and change the parameter
<param name="board_path" value="$(find aruco_gridboard)/data/layout-my.yaml" />
to your new yaml file.
Print your image.
Remark
The size of your grid board determine the range of your aircraft. As mentioned before, the grid board act as mock GPS system. If the board is too small, it will easily lose its sight on markers. It is recommended to create the markers big enough for your aircraft too see at its altitude. At least 4 markers should be visible by the aircraft.
Camera Calibration
This tutorial is referenced to the ROS.org
Prepare the checkerboard
Download the checkerboard here
The checkerboard is already with known dimension, which are 108mm squares. To print it on a A4 size paper, open the printing option dialog before printing and adjust the percentage size. I diminished the checkerboard to 20% of its original size, so the squares became 21.6mm.
Calibration
Make sure raspicam_node has been installed in Raspberry Pi
launch the ROS node and enable raw image
roslaunch raspicam_node camerav2_1280x960_10fps.launch enable_raw:=true
Run the Calibration Program
rosrun camera_calibration cameracalibrator.py --size 8x6 --square 0.0216 image:=/raspicam_node/image camera:=/raspicam_node
or
rosrun camera_calibration cameracalibrator.py --size 8x6 --square <square size> image:=/raspicam_node/image camera:=/raspicam_node
if you have a customized checkerboard
​ Remark
​ if camera_calibration is not found, run:
​ ​ sudo apt-get install ros-kinetic-image-pipelline ​
​ you will need to remake the raspicam_node after running the command.
A calibration window which highlight the checkerboard will pop up. Rotate, tite, and move the checkerboard slowly until the X, Y, and Size bar are filled up. When Calibration button lights, press it. The window will freeze but it is working. Wait for it patiently.
Something like this will be shown in the terminal:
D =  [-0.33758562758914146, 0.11161239414304096, -0.00021819272592442094, -3.029195446330518e-05]
K =  [430.21554970319971, 0.0, 306.6913434743704, 0.0, 430.53169252696676, 227.22480030078816, 0.0, 0.0, 1.0]
R =  [1.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 1.0]
P =  [1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0]
# oST version 5.0 parameters
[image]
width
640
height
480
[narrow_stereo/left]
camera matrix
430.215550 0.000000 306.691343
0.000000 430.531693 227.224800
0.000000 0.000000 1.000000
distortion
-0.337586 0.111612 -0.000218 -0.000030 0.0000
rectification
1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
projection
1.000000 0.000000 0.000000 0.000000
0.000000 1.000000 0.000000 0.000000
0.000000 0.000000 1.000000 0.000000
Switch back to the calibration window and click commit to save the result.
​ Remark
​ If Segmentation fault is shown after commit, check if this file exist:
	~/.ros/camera_info/camerav2_1280x960.yam
ROS need to be re-launched to apply the calibration data.
Troubleshooting
If package not found is shown, run:
sudo apt-get install ros-kinetic-rqt-reconfigure
If found no plugin matching is shown, run:
rqt --force-discover
and select the reconfigure in the pop up window
Okay I was just checking
In another page in ardupilot.org. It tells you to set mavlink1.
Both of them should work. It is an option. I have tested both mavlink1 and mavlink2 will work.
Run all Components
Correct Some Codes Before First Run
If you cloned the simple build, no need to edit the file
Edit the file ~/catkin_ws/src/aruco_gridboard/data/layout-my.yaml
Change the line
<param name="camera_info_url" value="package://raspicam_node/camera_info/camerav2_640x480.yaml"/>
to
<param name="camera_info_url" value="package://raspicam_node/camera_info/camerav2_1280x960.yaml"/>
This is because the camera was calibrated with resolution of 1280x960.
Start all ROS Nodes
Connect the aircraft to ground station (eg: Mission Planner) on your remote computer.
Switch back to the Raspberry Pi. Use SSH to login to the Raspberry Pi in every terminal if you are not testing on ground.
Launch raspberry pi camera node module:
roslaunch aruco_gridboard detection_rpicam.launch
Launch mavros module:
sudo chmod 666 <tty port>
OR
if you did not set default communication port.
Wait for the EK2 ready, until Request for home position shows up. Open a new terminal, run:
rosrun aruco_gridboard set_origin.py
to set data rate and origin point of your drone. After the python script start, the aircraft should be located in somewhere in Italy.
For the first time or if you want to configure the camera, open a new terminal and run:
rosrun rqt_reconfigure rqt_reconfigure
A window will show up and camera parameters can be modified here. For example, select these 2 checkboxes as show below if you mounted the camera upside down.
rosrun rviz rviz -d catkin_ws/src/aruco_gridboard/data/aruco_grid.rviz
The rviz should be opened and two 3-axis pose should be at the middle of the screen. They represent the /local_position/pose and vision_position/pose topics, which are the position relative to the aruco board.
Go to the left top corner and find the image tag. Change the topic to /image/raw. The real time image from camera will be shown in the bottom-left corner.
You will see that pose of vision_position/pose change according to the angle of aruco board observed by camera. Pose of vision_position/pose corresponds to the EKF measurement on the Cube. Because of the EKF, vision_position/pose will not change immediately but slowly move to vision_position/pose.
There will be a small delay between the actual movement and pose. The delay can be reduced by increasing the stream rate but please consider the processing power of Raspberry Pi.
The vision_position/pose may not be a flat standing even if the camera is flat. The problem may be located in image processing part. It is still functional anyway.
Load Robot Model to RVIZ
If you want to learn more about URDF model, please visit ROS.org
Install URDF_tutorial Package
Open a terminal and run:
sudo apt install ros-kinetic-urdf-tutorial
Test if Successfully Installed
Go to the package location
roscd urdf_tutorial
Run the default URDF
roslaunch urdf_tutorial display.launch model:=urdf/01-myfirst.urdf
You should be able to see a red cylinder at the middle of RVIZ.
Add Necessary Files
If you cloned the simple build, skip to next session.
Go to my github and clone the following files/folders to the corresponding folders in ~/catkin_ws/src/aruco_gridboard/
data/aruco_grid_model.rviz
launch/detection_rpicam_model.launch
meshes
script/pose_to_tf.py
urdf
Prepare Robot Model
The robot models can be built in the urdf file or load a mesh file into urdf file. If you are using a Raspberry Pi, it probobly would not have enough processing power to load a mesh file.
You can read the urdf_tutorial on ROS.org or look into ~/catkin_ws/src/aruco_gridboard/urdf/test.urdf to learn how urdf works.
You may also download a mesh file, such as .STL, from other websites and load into your urdf file.
To do this, put your mesh file in ~/catkin_ws/src/aruco_gridboard/meshes
Then, change the content of ~/catkin_ws/src/aruco_gridboard/urdf/aircraft.urdf to:
<?xml version="1.0"?>
<robot name="aircraft">
  <link name="robot_link">
	<visual>
      <geometry>
		<mesh filename="file://$(arg meshDirectory)part1.STL"/>
      </geometry>
    </visual>
  </link>
</robot>
which “part1.STL” is the file name of your mesh file
~/catkin_ws/src/aruco_gridboard/urdf/aircraft.urdf and ~/catkin_ws/src/aruco_gridboard/meshes/20_min_drone.STL are drawn by me. You may use them as default.
Solidworks
If you used Solidworks to draw the STL file, put it in the meshes folder and run:
sed -i 's/^solid/robot/' *
before using it.
Run Everything
roslaunch aruco_gridboard detection_rpicam_model.launch
~/catkin_ws$ roslaunch mavros apm.launch
OR
~/catkin_ws$ roslaunch mavros apm.launch fcu_url:=<tty port>:<baud rate>
~/catkin_ws$ rosrun aruco_gridboard set_origin.py
Convert the /mavros/local_position/pose to tf datatype
rosrun aruco_gridboard pose_to_tf.py
rosrun rviz rviz -d catkin_ws/src/aruco_gridboard/data/aruco_grid_model.rviz
A robot model will be bound to the 3-axis pose of /mavros/local_position/pose
