Issue with CubePilot GPS Lock: Takes Too Long to Acquire Signal!
Hi everyone,
I have recently started using a CubePilot system with the Here3 GPS module and I have been running into an issue. The GPS takes an unusually long time to acquire a proper satellite lock…, sometimes exceeding 5-10 minutes even in clear open areas. I have tried moving to different locations, updating the firmware and ensuring the module has a clear view of the sky, but the problem persists.
CubePilot Orange with the Here3 GPS module
Firmware updated to the latest version (ArduPilot)
Powered via the standard carrier board
Could this be related to interference, configuration settings, or even a hardware issue: ?? I also noticed the GPS LED remains yellow for a long time before finally turning green.
Any tips on improving GPS lock speed or troubleshooting further would be greatly appreciated !! If anyone has faced a similar issue and found a solution, please share your insights. I have also searched on the forum for the solution related to my query and found this thread https://discuss.cubepilot.org/t/here-2-gps-signal-anomaly-power-apps but couldn’t get enough solution.
Thank you in advance !!
With Regards,
Daniel Jose
Have you left the unit on for several minutes after a lock to make sure the almanac is upto date? (That might not be a thing anymore) Can we see a picture of how it is installed?
