That’s too bad because for many survey applications RTK isn’t really needed as posterior accurate positions are sufficient and RTK is just another failure point if the link drops out etc.
I have been using a an EMLID for PPK and works well, just the integration with the pixhawk is a little less robust, so for the moment will continue will this approach.
Seems the upgrade path to PPK for the HerePro 3 is a bit complex due to UAVCAN limitations so either that would need to be upgraded to support raw gps or a different communication protocol would be required.
Not sure if there is memory in the Here Pro to store the raw GPS data, and a way to get it out.
Yes. The upgrade process for Here3 to achieve PPK is complete because this is not a function by design. It’s more like making it work under limited resources.
I would suggest waiting for the further updates on HerePro.
