When I record video with OGC in the ground station the video stream freeses for several seconds but than recovers normally. While waiting for the video to recover, in the past I could navigate with the map display.
Today it got worse: First the video did freese and did not recover and then after some seconds whole QGC freezed. No Map update. I pressed RTH but it obviously did not work. I killed the QGC task, restarted QGC and found my plane far, far away…(I was in position mode with a FW).
With the last watts I managed to do an RTH.
Any idea, what caused the problem? Anybody having the same issue? I found an old task describing similar problems, but from the time before the “stable” version and without a solution.
Can anybody help?
Best regards
Peter
