Ethernet on the Herelink 1.1
I recently acquired a Herelink 1.1 system. Using the associated documentation I was able to connect from the exposed port on the air unit to an RJ-45 configuration. From there I statically assigned a companion computer an IP on the 192.168.144.0/24 connected via the RJ-45. From that companion computer I can interact with any node in the 192.168.144.0/24 and thus I can route from the air unit (192.168.144.10) to the ground unit (192.168.144.11).
If I am following along with all the postings related to this, even with with Herelink 1.1 I still should need a USB to Ethernet adapter of some kind. I’ve tried tonight with some of the listed adapters in the various posts but none of it lead to success with respect to communicating to the 192.168.144.0/24. I tried various manual route additions on both ends and it still failed with respect to the companion computer and a node on the same network ground side as the 192.168.43.0/24.
Using tcpdump on the airunit I saw some promising traffic on what I remember being a 192.168.0.0/24, but I could be off on the range. This is useful from a routing concept but without root on the ground unit further routing modifications are impossible.
What is the recommend way to tap into the new Ethernet capabilities of the Herelink 1.1?
can you draw a picture/map of your layout.
ie where everything is connecting?
Hello Michael,
Thank you for the response. Here is what I am trying to achieve:
i have not tested but
laptop needs a static route to 192.168.144.0/24 via 192.168.43.1
companion computer needs a static route for 192.168.43.0/24 via 192.168.144.11
192.168.0.0/24 is an internal network, and i wouldn’t complicate that at this point
you can get rtsp video from
192.168.43.1 or 192.168.144.11
and mavlink from
192.168.43.1 or 192.168.144.11 port 14552
side note, you might not need to do anything on the laptop side, as it will likely be the default gateway… assuming you only have 1 network connection that is to the hotspot.
Hello Michael,
I am happy to confirm that it is working. Thank you for the details that I had missed. The USB to Ethernet adapter is now 100% no longer part of the equation.
Hi Micheal_Oborne
I have a similar issue. Your recommendation did get the video and mavlink displaying from a nextvision Trips2 Track unit to the Herelink controller.
However, now to get that to connect to mission planner on a laptop is a entire new struggle on its own. Is there something is could check or do to get it working? I’m sure this is just a IP related issue but for the life of me can not get it working.
Did you ever figure it out? I am having the same issue with a Colibri2 and Trip2 setup… Did you find a solution?
Hi
Can you explain this more briefly.
I have connected herelink v1.1 through 5 pin RJ45 connector to Jetson orion ethernet port
Now I’m unable to ssh or vnc to my jetson nano.
Can you explain the process?
@arpit_workspace Check that you don’t accidentally have the boot order running with PXE before Jetson memory. I had such a problem with Orin.
Probably the easiest way to do it is to go into the Jetson “bios” by pressing ESC at startup with the HDMI screen connected and change the boot order.
I tested the provided route and that makes everything work.
On the main PC connected to Herelink Ground unit via Hotspot
route add 192.168.144.0 MASK 255.255.255.0 192.168.43.1
On the companion PC connected via LAN tiny cable to hearlink air unit
route add 192.168.43.0 MASK 255.255.255.0 192.168.144.11
I have now full bi-directional LAN.
thank you @Michael_Oborne
Hello everyone,
I am also trying to achieve same thing but instead of companion i have camera(viewpro) gimbal connected to ethernet port of Air Unit.
I am getting rtsp feed to my herelink controller but facing problems to establish connection with laptop by using herelink hotspot.
I am attaching image of the IP/gateway related options which i can change in my camera setting.
Please help me how i can get it connecred to my laptop
SAVE_20240226_114722
Question to the Mindhive.
I have a single RTSP camera, a Herelink V1.1 and a Raspberry pi. How would i be able to connect all three so i can get image both on Raspberry and V1.1 airunit?
