Could be your carrier board, contact your reseller
Tried different board and different cube. Still no
My answer was to @canterobb
Understood, we are having the same trouble.
Can works on Rover 3.5.1
Still no data populated in SLCan
SLCAN will only work with latest master
Is it possible that the board has 3 bad ports? The can2, the gps1 and the gps2? in that case I buy only the board, or is it better to buy board + cube?
thanks
Not likely, but worth checking
Have you tried switching to Serial / I2C and flashing to rover and then back to plane or copter to see if it would work plugged n to GPS1?
yes, we also tried that option, now I have ordered another pixhawk 2.1 complete, I hope to be lucky this time and that my unit arrives without problems.
I have one black cube and one blue cube that I have been flying for sometime now without a problem. This new one with the Here2 has really been aggravating to say the least. I hope you have better luck with new cube.
I got my new cube and my new carrier board, faster than I expected, thanks getfpv.com
but my problems are not solved, I can not make the here2 work with the cube.
I’ve tried it in can mode and it does not work.
I have tried in i2c mode and it does not work.
the gps here2 works perfectly on a radiolink pixhawk, obviously in i2c mode
The good thing about this is that my previous cube is good.
the bad thing is that I have spent 300usd and I still have the problem.
What cable are you using on the Cube setup?
I’m not sure if I understood the question correctly. I am using the original 8-wire cable connected to the gps1 port when I use the i2c configuration and when I use the can configuration, I use the original 4-wire cable.
How did you connect it to the radio link board?
Today I made several tests to find out what the error is but I am very confused.
I tested my GPS here2 with a Pixhawk radiolink and it worked perfectly. I could say that GPS here 2 is fine.
I tried here2 with the same cable and the same firmware with a pixhawk clone and it didn’t work, it means that here 2 doesn’t work with all pixhawk
my 4 test units, all with the same gps and ardurover 3.5.1
testing my cube with 2 gps and it didn’t work with any.
My other cube didn’t work with the GPS here2
I am very confused, will it be possible that my two carrier boards, both are new, are damaged at the factory?
We need help with this urgently.
thanks
The common things with your failed cube testing is the cable. You are using a different cable with the other tests (obviously)
Personally, I’d RMA the carrier board anyway just to be sure.
I’m sorry this has not been easy for you.
So… not even the safety button light shows up?
Definitely check if power is on the connector.
The 8-wire cable is likely to have problems, today I’m going to focus my tests on this cable, I don’t remember if I turn on the safety switch.
I will test continuity in the cable to see if I find any problem.
I’m also waiting for the new here2 with the new cable, so we can get out of doubt.
the only thing that worries me about this theory is that mgrimes1907 and pedrosa also seem to have the same problem
One issue at a time. Similar symptoms can have different reasons. I suspect yours is the cable… not sure on theirs yet
Hi, I already received my new here2.
it worked!!! the new gps here2 worked with my new cube 2 and it also worked with the old cube 2, it also worked with both cables.
that is, the old cube was good, the new cube was good, the old cable was good, the problem is in my old here2, although I want to make it clear that my old here2 is not completely bad, because it works with my radiolink pixhwak.
I think there is something wrong with the firmware of my old here2.
