Thank you guys, I will add the 2 latest cam reported working
Anyone else getting a huge delay when viewing video stream through rtsp?
There is a recent post
Where GoPro 4 seems to work perfectly. Iām almost decided to acquire herelink 1.1, but I need someone to change the beginning of this post, as it says GoPro 4 doesnāt work anymore. Iāve been trying to find why is the reason this camera doesnāt work anymore but no trace anywhere. Obviously I have to be sure that my GoPro 4 will work with latest herelink 1.1 before I buy it. Can anyone confirm this? @Julien @Alvin @Michael_Oborne.
Thanks.
Hi all,
Nobody to confirm this? @philip
i have one, so I will give it a try as soon I have time
Thanks a lot!!
Are you able trigger the gopro and capture images? also record footage
Camera recomendation? No really lol! I bought a Firefly Q6 and itās ok⦠For driving my boat doing bathymetry. But at higher speeds where you need to actaully see stuff, maybe not. An engineer firm has asked me to fly my 18kg X8 with a Pheonix lidar through some tight canyon terrain. The Firefly isnāt even close compared to my old Connex Prosight. Of course the Connex has no range. There has to be something better with hdmi out.
Two new tested cameras with HereLink v1 @Julien:
Unmanned RC - ADTi Surveyor 24L
Unmanned RC - ADTi Surveyor 42S (low HDMI signal - Gremsy HDMI passthrough is problematic)
Both is cappable of HDMI together with geotagging & full camera control via MavCam (ENTIRE)
Check TOPOTEK HDMI Series Cameras with high-performance and low price
Hi, were you already abled to try the GoPro hero 4. I would really appreciate it.
No unfortunately. As I do not used it since a while the two batteries I had were totally dead. So I offered the Gopro to someoneā¦
I can confirm that the Herelink Industrial works. But I can only get 720P@30 to work with Herelink.
I have tried powering on the camera first, and then the Airunit.
Anyone got 1080p to work with the Herelink Industrial 4k Split?
Thanks.
The menus in the camera are obtuse but once you get it to output 1080p30 or 1080p60 it does work with the Herelink
Hi Craig
I am quite certain that I have set the output to 1080p30 (both recording and HDMI), but still no luck. What firmwares are you using?
Thanks.
GoPro 8 doesnāt have HDMI port. How do you connect this to the Herelink air unit.
Go Pro Hero 8 does not have an HDMI port. How did you connect the camera to the Herelink Airlink unit
Are there any NDAA compatible cameras that are good for FPV?
The Sony and Wiris cameras are nice but they are a full payload by themselves. And the GoPros donāt integrate well (need to be manually powered on for each flight, can do wacky things).
I have been using the GoPro 11 Black with the media mod. It seams to work well at 1080p 30fps. I was actually surprised at how easily it started working once I plugged it in to HDMI port.
Has anyone tried the Siyi A8 with the Herelink???
