run flasher from commandline
I have updated to the most recent version of Herelink and QGC has stopped working. Whenever QGC is launched it displays âWaiting For Vehicle Connectionâ even though the ground unit is linked to the air unit which is all ready to go. When the Drone is hooked up to Mission Planner it shows throttle etc. inputs from the ground unit but QGC will not recognize my drone.
i am having the same issue now and nothing i have tried has worked
Download the new air unit firmware thru the Herelink and all will be fixed.
I have tried this. Did not solve my issue
I tried this but it made no difference. It appears to be a problem with communication between QGC and the ground unit. The autopilot receives stick input but QGC will not recognize the connection.
I canât switch the HDMI video source with MP. I asked the manufacturerâs after-sales service, and the after-sales service said that MP canât switch either. I now refer to the MP code and canât switch. Is there really no way? This matter has been put on hold for nearly half a month
Go with QGC and Px4 firmware. Ardupilot has lots of issues .
Mission planner can definitely switch video if you are talking about the desktop version.
What an absolutely stupid and incorrect answer!
Ardupilot is the worldâs widest used open autopilot software and trusted by governments and commercial systems worldwide.
If you insist on trolling, please do it elsewhere.
Crazy comments!
If you know the solution to the query, why didnt you reply. rather than being a troller yourself.
Which switch is the video source? Iâve tried each one, but itâs useless
ă Current MP version 1.3.77
I did answer, and our team has been responding on another thread.
I tried, but there was no response. I didnât switch the video picture. Hdmi1 and hdmi2 were connected to the camera and were working normally
Do you have the new dual video enabled? If so try the V2
Tried, it didnât work
The app I am developing has been delayed on this issue for a long time. I want to debug through the existing software, but I get nothing!
What do you mean by âthe appâ you are developing?
Is this not a standard application?
